586,052 active members*
4,157 visitors online*
    May 2012
    First success after build
    This is the first video
    [ame="http://www.youtube.com/watch?v=wD7IoiCOCEI"]Video 1[/ame]
    The second video
    [ame="http://www.youtube.com/watch?v=rsgi9bBKUqo&feature=channel&list=UL"]Video 2[/ame]
    The sign is for a Sears store's back entrance to stop customers from walking in to the shop area.
    As you can see from the 1st pic, the router had issues. After hours of troubleshooting and re-calibrating and so on. I found that a set screw on my Y-axis pully was loose, and it would move intermittently causing lose of location. Note to self " Check everything occasionally".
    Attached Thumbnails Attached Thumbnails DSCI0336.JPG   DSCI0338.JPG   DSCI0341.JPG   DSCI0344.JPG
    Nov 2006
    1036
    Congrats!!
    You've probably already done it, but, if not, I'd suggest you use some LocTite to prevent set screws and such from becoming loose.
    Jun 2012
    25
    Well I think you have gotten somewhere. It is so funny that sometimes the fix is so little but so great. The cuts look clean. Great work. You have any pics of your cnc?
    Jun 2005
    19
    FYI: Lose the apostrophe.
    "EMPLOYEES ONLY" is correct.
    EMPLOYEE'S is possessive not plural.
  1. Soggy success
    By cncadmin in forum EnRoute
    Last Post: 03-30-2012, 02:40 AM
  2. Success but still need help
    By machines2go in forum CamSoft Products
    Last Post: 10-12-2011, 01:48 AM
  3. Finally - success with a IH CNC Kit
    By sdfoiler in forum Charter Oak Automation Support Forum
    Last Post: 03-13-2011, 07:57 PM
  4. Sketchup success in CNC?
    By ZipSnipe in forum Uncategorised CAM Discussion
    Last Post: 02-27-2011, 04:59 PM
  5. Success!!!!
    By Smitty911 in forum Benchtop Machines
    Last Post: 03-02-2008, 04:13 PM
