586,459 active members*
3,255 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Tapedrill Mate T 1008 and PS585 alarms
Results 1 to 5 of 5
    May 2009
    106
    We have a Tape Drill Mate Model T, We are having 1008 and Ps 585 alaRMS.
    Control is fanuc 0MB 1991 vintage.
    It is giving us 1008 belt slip alarms. The turret is not binding, the belt is very tight and the seperate encoder belt is tight . We have swapped the Spindle drive unit, the seperate encoder and the motor, no change.
    If we take out 2 of 3 detent balls it will run ok. I suspect tht the following error for turret index parameter is set too low. but fanuc is not able to tell us which one it is.
    I am almost positive it is in the 9000 parameters. The machine is able to Orient the spindle every time ok . It is only after that the indexing gears are meshed and it rotates that it fails .
    If any one has a description of the spindle index parameters it would be great. They seem to be located from 9000 to 9200. Thwey are labeled like ex.
    p 9150 is described as ERMSP possibly, error spindle moving spindle ?
    Jan 2007
    18
    tape drill 9000 parametres
    i am also having same type of problem of alarm of 581 while commanding M19 in same machine. again requesting if someone has full text of 9000-9200 parameters.
    Oct 2006
    6
    Re: Tapedrill Mate T 1008 and PS585 alarms
    Turret orientation Parameters are 9122 and 9140 in both parameters value should be same increasing or decreasing value will change the orientation angle.
    Sent from my GT-N7100 using Tapatalk 2
    Sep 2012
    182
    I'm starting to get the 585 alarm with 401 Vrdy on the same machine.
    anyone find the cause?
    Fanuc robodrill ps alarm 584 at the time at mo6 command please help
  1. Replies: 13
    Last Post: 08-15-2018, 06:22 PM
  2. Seiki-Seicos LII Bubble memory Alarms --- Help on recovering from alarms 104,144,105
    By AZTEXAN_MIMXII in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2013, 08:59 PM
  3. Looking for 1008 or 1010 low carbon steel
    By orangelss in forum Want To Buy...Need help!
    Last Post: 05-11-2011, 06:34 PM
  4. J403 1008
    By gr_mich_mush in forum Material Machining Solutions
    Last Post: 03-17-2011, 12:54 PM
  5. Alarm 1008 D450 SET ERR.
    By quasarix in forum Fanuc
    Last Post: 05-14-2010, 07:28 AM
