586,075 active members*
4,018 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Handy timing belt/pulley selector chart
    Jul 2003
    7
    Found this handy toothed belt/pulley calculator chart today, found it very useful so thought I would share it.
    micromagic systems - home
    Jun 2012
    25
    Awesome thanks. I wished I would have had this chart about 1 month ago. THanks you for sharing again.
    24221
    Does it warn of too low tooth engagement if the ratio is large and centre distance is too low?
    This is also one that does.
    Precision Mechanical Components Timing Belts Pulleys Spur Gears Couplings Bearings Sprockets Retaining Rings Brakes Helical Gears Clutches Universal Joints
    Al.
    Albert E.
    May 2006
    50
    Quote Originally Posted by JohnA View Post
    I downloaded it and....nothing. It doesn't work.
    Jun 2011
    B&B Manufacturing has a belt length calculator at Belt Length Calculator | B&B Manufacturing.
  1. HTD timing belt pulley
    By R.thayer in forum Uncategorised CAM Discussion
    Last Post: 11-14-2013, 10:08 PM
  2. timing belt walking off pulley??
    By gateman in forum DIY CNC Router Table Machines
    Last Post: 04-19-2012, 06:37 PM
  3. What is a timing belt and pulley ?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 02-18-2011, 01:38 PM
  4. Reinstalling timing belt pulley
    By snapman in forum Linear and Rotary Motion
    Last Post: 01-04-2007, 05:46 AM
  5. SDP-SI timing belt pulley question
    By cnc2k in forum Mechanical Calculations/Engineering Design
    Last Post: 08-21-2005, 08:17 AM
