586,762 active members*
8,322 visitors online*
Results 1 to 6 of 6
    Feb 2011
    11
    Question SX3 spindle speeds
    Ok, I'm sure this question has been asked a thousand times, but is there any easy fix to the low spindle speed of a stock X3 mill?
    My question/problem is that I would like to use small cutters, on the order of 1/8" on brass. If I understand feeds n speeds, there is no way to get decent quality cutting out of a 2000 rpm spindle head. If I am wrong, please forgive me, I"m just learning.
    With that said, what is the smallest cutter I can expect to use with this machine? Assuming I will be cutting brass, steel, and such. I got this machine because I plan on a very small work envelope and the bed travel is more than satisfactory. I didn't want to get a Taig because I wanted the rigidity.
    I have a CNC Fusion kit installed, with Mach 3.
    Feb 2011
    11
    Said partially tongue in cheek....
    Since I didn't get any response to my questions, I will attempt to answer them based on the response I received.
    A: Just check out previous threads. Don't bother us with questions that have been asked a thousand times. The answer is yes.
    A: Please go back to the books and learn speeds and feeds, we have more important things to do than answer questions that can be resolved by a little bookwork. Besides if you don't fully understand feeds n speeds you should stay away from sharp objects. If you do fully understand speeds and feeds you wouldn't be wasting our time with this questions.
    A: See second half of above answer.
    A: Are you bragging or complaining....
    24223
    Possibly fit a BLDC controller fed off of 240vac such as A-M-C etc and run the motor at its maximum rated RPM, instead of half as it comes?
    That is if it is the motor and controller I am thinking of!
    Al.
    Albert E.
    1695
    You can add add a secondary high speed spindle. One of these might be suitable:
    Dental 35K RPM Electric E-Type Micro Motor For Marathon & Low Speed Handpiece | eBay
    I will try making my own using abec 3 skate bearings.
    24223
    There is this link also, High Speed Auxiliary Mill Spindle Plans
    Al.
    Albert E.
    Dec 2009
    I mounted a dewalt 611 trim router to my X3 and it works great.
    Its rigid, fast and quiet and it's the spindle of choice among the small cnc router crowd.
    I plan on disabling the soft start feature on it and then adding an aftermarket speed control for it to slow it down, useful for some applications. The slowest speed right now is about 15k. Top speed is over 27k.
  1. SPINDLE SPEEDS
    By 5artist5 in forum Taig Mills / Lathes
    Last Post: 04-07-2009, 03:25 AM
  2. Feed rates / spindle speeds for HF spindle
    By yngndrw in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2009, 04:46 PM
  3. Spindle Speeds
    By martindugdale in forum CNC Tooling
    Last Post: 03-29-2007, 02:46 PM
  4. spindle speeds
    By fourperf in forum Fadal
    Last Post: 11-26-2006, 01:59 AM
  5. Need max spindle speeds for metal
    By bgolash in forum MetalWork Discussion
    Last Post: 04-24-2005, 02:15 AM
