586,089 active members*
3,948 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > North America RFQ's > Mill 5 1/2" Aluminum circle 1" thick with center post down to 1/8" Thick
Results 1 to 6 of 6
    HI,
    First off I am trying to get 5 of these made. It is a very basic design the rough mesurments are 5 1/2" outside diameter, with a 3/16" wide wall on the ring, with 10 clearence holes in it. The center is about 5/8" across with a 3/8" hole in the center of it. I also would like 2 rings cut into it for o rings for this needs to be waterProof it will be under water in my pond working with my fountain set up I have with my christmas lights. I attached a drawing that is an old design just so u have an idea what I am refering to with the dimentions, ill try to get an accurate drawing real quick. I also have a design for some air cylinder operated valves i would like cnc'd out of aluminum if the price is right also so there are a few things I need done and multiple of each to be done.
    Thanks for any help in advance!
    -Will
    The picture wouldnt upload before here it is.
    Will
    Oct 2010
    103
    Quote Originally Posted by WRichards View Post
    ....... ill try to get an accurate drawing real quick. I also have a design for some air cylinder operated valves i would like cnc'd out of aluminum if the price is right also so there are a few things I need done and multiple of each to be done.
    -Will
    When you have that available, feel free to send to [email protected] . I would be happy to offer a quote on that
    Thanks for the interest I'll have accurate drawings tonight and I can post here and send to whom ever is willing to quote me.
    Thanks for the help!
    -Will
    I have a more accurate drawing with dimentions now to anyone else who might be interested!
    THERE IS A WRONG DIMENTION
    There are 10 holes around the outside it says the diameter is .72, this should be .1440.
    I have emailed it to everyone who has contacted me for a quote already.
    -Will
    Oct 2009
    26
    Hi! I'm absolutely sure that I could offer you a very good quote on this job. I do parts similar to this quite often. What files would you be able to offer if I got the job? My quote depends on whether or not I will have to "re-draw your drawing." Please shoot an e-mail to [email protected] to further discuss this RFQ. You can also check out my website at www.ChalkPrecision.com. Thanks for the opportunity, I look forward to hearing from you!
  1. Replies: 1
    Last Post: 01-14-2011, 04:43 AM
  2. Cold-rolled steel plate, 13"x24", 1/2" thick.
    By Odin in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:00 AM
  3. Best Mill for 1" thick Aluminum?
    By gtslabs in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2004, 04:37 AM
