Hey everyone,
Just wanted to see if I could get some pointers on making finishing passes on the outside profiles of the parts I work on. I write toolpaths for and operate a PCNC 1100 for the company I work for, and up until now, I don't know of a good way to fixture a part for a full depth finishing pass on the outside edge. The obvious limitation is that the vice jaws are in the way when trying to do this.
The best way I have found to do it thus far is to make a simple fixture which I bolt the parts down to after some features are already cut into the part. But, for runs of about 2 or 3 parts, making a fixture isn't all that time efficient. For parts I don't use fixtures on, I am usually left with using tabs on the part which I cut off and file down, leaving unsightly marks every so often.
As an example, a part I'm working on right now is a 2.5" x 4" 6061 0.125" thick aluminum plate. I'd like to cut all of the inside features, and then do a finishing pass on the outside, but apart from making a fixture, I don't know of a way to do it. Many of the parts I work on are panels or thin parts with holes/cutouts in them, or engravings. Really not a whole lot of 3d geometry.
Any advice? Or am I stuck with making simple fixtures?
Thanks!
