586,061 active members*
4,416 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Fanuc Series 31i controller question
    Feb 2011
    We are having problems burning up drills on the job we are currently running. I would like to set it up so when the machine reaches a certain horsepower or thrust limit it stops drilling before it burns up. Is there a way to do that with a Fanuc Series 31i controller? This is a brand new machine (Hyundai 1000mm horizontal machining center), I haven't been able to find anything in the book on this...
    Thanks for any help.
    Aug 2009
    684
    Our 31i has a tool moniter accessed through the custom1 screen. So, yes, there is a way. It has been created by the MTB, however (Doosan). I think it would only change the tool after it reaches a certain threshold with the current tool - it wouldn't halt the cycle.
    So, maybe Hyundai can give you a similar option.
    DP
    Another option that has just occurred to me are real-time macro interrupts (//ZDO's) , though I haven't used them myself, there should be a chapter in your manual. I suspect that you could write your own routine that jumps out of the loop if a condition is met. You would need to find out if there is a RTM variable associated with the spindle load meter. I haven't found anything on RTMs on any of the forums, sorry.
  1. GE Fanuc Series OM Controller
    By otto.wilcken in forum Fanuc
    Last Post: 03-14-2012, 02:27 AM
  2. Replies: 3
    Last Post: 09-19-2011, 03:59 PM
  3. fanuc series 31i model A5 controller
    By yaman in forum Fanuc
    Last Post: 02-14-2011, 09:19 PM
  4. Fanuc 160i-M Series Controller
    By kevin08 in forum Fanuc
    Last Post: 07-11-2008, 03:05 PM
  5. GN6 Series Fanuc Controller
    By CBMach in forum Fanuc
    Last Post: 08-16-2005, 01:46 AM
