I've been trying to figure out what is going on with my coolant. Can't seem to find any scenarios like this so I thought I would ask.
I had quite a bit of tramp oil floating on my coolant, so I installed a Zebra tube skimmer. I ran it for about a week for a few hours a day and it removed the oil slick. Though coolant was now looking a bit light in color. I guess the oil skimmer will also remove the oil mixed in to the coolant making up the proper 5% mixture. Is this true?
After running the skimmer I checked the coolant with my refractometer, and it was only at 1.5% (should be 5%). Coolant was also on the low side, so I went ahead and filled it up and brought the mixture to exactly 5% again. It looked perfect in color, and smelled right. Checked with the refractometer again the next day, and still perfectly at 5%.
I ran the machine for a few more days with the new coolant, then it sat for about 12 days without running. During this time I did not run the skimmer since the coolant was fresh and the mill was hardly run.
Today I checked on the coolant and there was a thin yet solid oil slick over the entire tank (except where the bubbler was bubbling). I have no idea where this oil came from since the machine is clean with fresh coolant, and there is no way that much oil could have come from the ways after a few hours of running.
Using my chip scraper, I mixed the coolant up in the tank and got rid of the oil slick pretty quickly. Though the color was not the clean blue it was before, again it looked light in color (and a little green). I checked the mixture with the refractometer and it was at 2%.
This is what is puzzling me. Does soluble oil coolant start to separate after it sits? Is this where the oil slick is coming from, and why my mixture ratio reads so low?
I loose about 2 to 3 gallons a week from evaporation, so I would imagine the mixture level would go up, not down. At this point, it seems I would have to mix another double batch or 10% ratio coolant for the 2nd time in a row to bring it back up to 5%. But it just doesn't add up.
The refractometer has been calibrated and checked with fresh water, and fresh batches of coolant before it gets mixed in and it reads perfect every time. Must be missing something obvious.
Any thoughts or comments on this?
Thanks.
