586,100 active members*
2,676 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V23 sweep funtion, unexpected results
    Mar 2006
    37
    I have been doing more 3D modeling in BC lately, and have run into a problem doing a sweep.
    The first curve (cross section) is perpendicular to the contour, but the resulting solid is on an angle for some reason.
    BOBcad File V23
    https://dl.dropbox.com/u/82376106/test-sweep.bbcd
    Any ideas?
    Steven
    Dec 2008
    4548
    Go to your profile and delete the .05 fillets and use utilities-trim extend-two entities and connect them to a rectangle again. Then run your sweep and run a .05 fillet on the resulting part.
    Attached Files Attached Files
    Mar 2006
    37
    Thanks Burrman,
    I will give that a try, but doesn't it seem like it should be able to do the sweep with any geometry? Why only a rectangle?
    Steven.
    Dec 2008
    4548
    Quote Originally Posted by vetsen View Post
    Well, yes and no.
    Although this sweep is fairly simplistic, BobCads sweep command is fairly simplistic.
    A basic rule in modeling is putting little radius' and detail on "after" or later in the process. Trying to make little radius' sweep around in 3d space makes the command more complex by nature. The command has to make a determination of profile orientation as it sweeps along in 3d space in relation to the path. The little radius' are throwing off the orientations autoplace, which for BobCads sweep command, is simplistic, as it is non-controllable.
    Although we should expect this case to produce a result.
    Following the simple rule will get you results, even with BobCads simplistic sweep. It will also be good for you to "train yourself" with this knowledge. It will help you even with more high end modeling packages to know the basics.
    Dec 2008
    4548
    So here's another way to make it work, considering the autoplace mechanism.
    Placing your profile within the bounds of the path, has it take orientation consideration from the path. (Here you also need to remember that BobCad works mostly in a single UCS "paper space". Note your profile and path are not on it)
    If you re-orient your profile and path to be on the active UCS, and also "seperate" from each other, then the autoplace mechanism will make a more intelligent decision as to the sweep. Then you can orient the result to somewhere in space after you have an object.
    So, attach to the top center of the profile, then chain select just next to it, then chain select your path at the end.
    This allows the auto place to work and you can rotate and translate the result into position. Example file attached.
  1. PROBLEM WITH G41 FUNTION ON DECKEL FMAP
    By IlFincoITA in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-12-2012, 11:52 PM
  2. Helpn for SSS funtion and HPCC Funtion on M720
    By fendy in forum Mitsubishi controls
    Last Post: 04-17-2012, 06:20 PM
  3. G54.2 Dynamic Fixture offset funtion (30i)
    By KBLANKE in forum Fanuc
    Last Post: 06-18-2009, 02:22 AM
  4. how do you use the fixture offset funtion
    By cob in forum Mastercam
    Last Post: 11-19-2008, 06:48 AM
  5. Replies: 4
    Last Post: 05-03-2007, 01:53 PM
