586,471 active members*
3,615 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Exporting a .stl file
    Nov 2005
    244
    I am using a product called VEGACNC, DNC Systems, Backplotters, NC Editors, Feedrate Optimization to verify my .nc
    code against.
    When I export a .stl out of Edgecam 2012R1 the .stl exports at the original C.S. not at the programmed C.S. I do not have a way to move the .stl
    file in my NC Verifier
    Is there a setting or way to export a .stl file for a chosen C.S.?
    Thank You
    Jun 2008
    125
    Hi camtd,
    As far as I can see (unless anyone else knows better) Edgecam will export the STL relative to the TOP cpl.
    The easiest way to get round this is get into the routine of using TOP cpl as your initial cpl.
  1. Exporting 3D in .dxf
    By AiR_GuNNeR in forum Uncategorised CAD Discussion
    Last Post: 11-20-2010, 11:04 AM
  2. Exporting a STL file with Rhinoscript
    By samg in forum Rhino 3D
    Last Post: 10-16-2009, 08:55 PM
  3. Replies: 1
    Last Post: 07-07-2009, 01:03 PM
  4. Help with exporting to dxf
    By CJdave in forum Solidworks
    Last Post: 04-20-2009, 04:22 PM
  5. Exporting BBC V22 file to IGS & Alibre
    By tikka308 in forum BobCad-Cam
    Last Post: 12-02-2007, 11:10 PM
