586,619 active members*
2,505 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 4 axis Nema 34, DM860A wiring help
    Oct 2011
    Ignore this post, the problem ended up just being solved by checking the step low active option in the ports and pins settings in Mach 3.
    for anyone who may come across this post in a search of help, if your having trouble. the linked schematics are helpful, this is picture of my wiring setup http://i.imgur.com/DyBoN.jpg I jsut added a bypass of the e-stop. and here is a video with accurate wiring as well [ame="http://www.youtube.com/watch?v=XFCJtXcW8t4&feature=related"]veliki steperi se okrecu - YouTube[/ame] and he goes into a good amount of detail
    Attached Files Attached Files
    Dec 2012
    Can anyone help??
    Hello Guys
    First of all hello everyone. I'm Yaz and I'm from UK. I'm beginer with CNC and my problem might sound silly.Tried find answer on the forum but with no succes.
    Got same set as speeddemon974 and connected everything in the same way as he showed on his video. Use Mach3 to control it with windows xp on my laptop. My motor spin but roughly and makes a lot of vibration.the speed is slow (one moment faster and second later slower) Changing velocity and acceleration in Mach3 doesn't help.Weird thing is when connected 25pin cable to the breaking board the green power light come on without power supply connected and when connected power supply after - the same light get brighter than before.
    Any suggestions or advice?
    RGDS Yaz
  1. Nema 34HST9805-37 and DM860A Driver
    By Dan911 in forum Stepper Motors / Drives
    Last Post: 10-02-2014, 04:33 PM
  2. TB6560 3 Axis 3A and Nema 23's I'm NEW to CNC.
    By ihacbook in forum DIY CNC Router Table Machines
    Last Post: 11-18-2012, 11:21 PM
  3. Someone please help with wiring nema 23 to TB6560 AHQ
    By coltac in forum Stepper Motors / Drives
    Last Post: 09-19-2012, 01:19 AM
  4. TB6560 3 Axis 6 Wire Nema 23
    By catabolic in forum Stepper Motors / Drives
    Last Post: 07-03-2012, 04:57 PM
  5. Wiring Nema 23 Motors
    By jamesrm in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2008, 04:23 PM
