Originally Posted by
rpm3000
Normally the manufacturer will give you a GPM rating. Not sure if Haas does this or not, but it's the only way to truely rate the system. PSI will depend on tool orifice size.
That is not actually correct. Pressure and volume are not the same. You can have a pump that puts out a 1000 gallons a minute but will not make much pressure.
Pumps for through spindle use should be rated as "X" psi at a specific orifice size and distance.
Pumps for volume generally use an impeller to get the fluid moving in a circle, then offer an escape opening for it to flow into and out. Pressure pumps use other methods such as gears that mesh and force the fluids through/out, like oil pumps for car engines or hydraulic pumps.
In use, the TSC will have a lot of pressure but not much volume. Large openings will greatly reduce pressure. But, remember that the opening in the pull stud is only about 3/16ths or so, so any tool opening over that will reduce pressure.
Have fun-----Mike
