586,068 active members*
4,239 visitors online*
IndustryArena Forum > CAM Software > UG NX > Renishaw Probing Post Processor for a 2012 Haas VM3
    Sep 2012
    I have a standard OMP40-2 in our Haas and we run UG NX 8.2 for out toolpath programming. Does anyone know where i can find or have a post processor that can post my probe sequence from UG NX to my Haas? NX is very little help as normal in these matters and i have no idea how to use there post builder software . Any ideas would be helpful. Thank You
    Sep 2012
    I wish! I believe you can do some simple probing using Generic Motion and the Macros built into your VMC... However for anything fancy, forget it, the time to make the program is going to be prohibitive.
    Look at Renishaw software instead, it works flawlessly with the HAAS's and the OMP-40, also not too expensive.
  1. Renishaw Probing on a 2012 Haas VM3
    By wincoaw in forum Haas Mills
    Last Post: 09-14-2012, 10:57 PM
  2. HAAS OTS Renishaw Probing Issue....
    By Doolie in forum Haas Mills
    Last Post: 09-13-2012, 02:56 AM
  3. Renishaw probing.
    By jpj1474 in forum Mach Wizards, Macros, & Addons
    Last Post: 05-02-2012, 11:18 PM
  4. POST PROCESSOR FOR RENISHAW PRODUCTIVITY+ PLUGIN
    By atrus9999 in forum GibbsCAM
    Last Post: 01-06-2012, 10:00 PM
  5. renishaw probing on haas mini mill
    By kwhite2 in forum Haas Mills
    Last Post: 09-30-2010, 10:51 PM
