586,119 active members*
3,493 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > I changed from synrad rf laser tube to glass tube and it is not working good
    Sep 2012
    I have a trotec with a synrad firestar t60, It was too expensive to regas it and I bought a reci tube 90w (from china) I conected but now is not working properly, it start engraving any logo with very low power and end also with very low power, if the head moves fast, the problems gets worst.
    A friend tell me that the problem is with ttl signal has low, the computer is sending low miliampers tha the new power supply doesnt work good, but this option is difficult to test it.
    If anyone has an idea of solving or maching the trotec system to a glass laser, i will apreciate very much your help.
    thanks
    david
    Sep 2011
    296
    Hi, David,
    Have you changed the powersupply at the same time, the two powersupplies quite different. And also the software parameters need to be modified. Maybe 1 or 2 cable lines should also be connected to the controlling card.
    In one sentence, not so simple.
    Melody
    [email protected]
  1. Glass 150 watt laser tube from ColTech
    By MonoNeuron in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-16-2012, 02:36 PM
  2. Water temp, glass laser tube
    By Chad Veich in forum Engraving Machines
    Last Post: 11-22-2012, 06:00 PM
  3. Difference between Chinese Glass tube and RF Tube...
    By InfernusDoleo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-08-2012, 03:44 AM
  4. how much cost synrad laser tube
    By oljeg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-01-2010, 03:37 PM
  5. What is better option between glass and RF laser tube
    By aussiemate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-02-2010, 08:30 AM
