586,072 active members*
4,652 visitors online*
Results 1 to 10 of 10
    Sep 2012
    fanuc part program back-up
    I have a Fanuc 310i control on a G&L mill. I want to save all of the part programs on an external drive. I can't locate a folder on the C drive with the part part programs in it. We have about 10 different folders with 10 to 20 programs in each. If I use the outputting programs instructions from the book it only saves the one folder I am in and combines all the files into one file. Please let me know how to save the folders and there content in a more user freindly form.
    Aug 2011
    2517
    punch them out one by one.
    or punch everything and use a program to split them into their original files again. a program to do that is attached. it came from one of our nice CNCzone users.
    the program expects the all-punched file to be named all-prog.txt and it must have a % at the top of the file.
    then simply double click on the .exe and it'll split the large single file into separate programs.
    try to better manage your programs instead of storing them in separate folders to avoid this problem in future......
    Attached Files Attached Files
    Nov 2012
    thanks a lot.
    have you got project file for this program
    Aug 2011
    2517
    no
    Sep 2013
    Quote Originally Posted by fordav11 View Post
    WOW this CNCProgsep.exe is awesome Thanks a bunch!!
    Jul 2016
    30
    Re: fanuc part program back-up
    If you aren't comfortable running a random executable posted to a forum without source take a look at this project. This one is open source and it's really short. You can easily read the whole thing quickly. It has no external dependencies. It's 100% C#. It's also MIT license so you can put your company name on it, compile it yourself, and maintain it internally.
    https://github.com/A9G-Data-Droid/Sp...rogram-Backup/
    Cool Re: fanuc part program back-up
    ALL-PROG.TXT splitter has been created on VB.NET .
    https://sourceforge.net/projects/cnc-splitter/
    screenshot :
    How do you use it
    How do you use this?
    Jul 2016
    30
    Quote Originally Posted by Regulator1 View Post
    How do you use it
    All the information you need to run my tool is in the readme, clearly visible on the main page of the repo. If you don't know how to run command line utilities you should contact your IT dept.
  1. FANUC Oi Mate TD NC Part program dowload
    By kmarsus in forum Fanuc
    Last Post: 05-04-2014, 07:00 AM
  2. Trying to figure out how to do back side of part.
    By DREXENG2015 in forum BobCad-Cam
    Last Post: 12-25-2013, 12:59 AM
  3. Fanuc OT part program input rs-232
    By zschary in forum Fanuc
    Last Post: 11-04-2012, 10:27 PM
  4. Fanuc 180i-MB load part program
    By ulihuber in forum Fanuc
    Last Post: 03-18-2011, 01:12 PM
  5. old program back to cad?
    By Rob_N in forum G-Code Programing
    Last Post: 11-12-2009, 05:30 PM
