Originally Posted by
PriddyShiddy
Mine are set up as follows:
1. Haimer
2-9. open for odd tools I'm programs (like more drills than I have chucks so some are in er20 for that job)
10-14. drill chucks (have to expand this soon)
15-19. Face mills
20. 1/2" spot drill
21-39. utility tools (chamfer, tap, dovetail)
40-59. 1/8" tooling
60-79. 3/16" tooling
80-99. 1/4" tooling
100-119. 3/8" tooling
120-139. 5/16" tooling
140-159. 1/2" tooling
160-199. >1/2" (going to cut this down and did everything up 20)
200-249. <1/8"
Within each group I start with 2fl, 3fl, 4fl. within those it's stub, regular, long, radius, ball, special.
so I know without looking 100 is a 2fl sub rougher 3/8, 85 is a regular 2fl flat end mill etc.
Not to be critical, but that seems like a lot of extra trouble.
I will just number the tools as I need them.
So far the most I have used is 7, and when ever possible, I will use one tool for several operations to avoid tool changes.
The way I see it, when the machine is moving to the M998 position, I'm not making any money.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
