586,089 active members*
3,820 visitors online*
Results 1 to 2 of 2
    Sep 2012
    RFQ aluminium sheet - laser
    Hi guys,
    Just wondering if someone could provide me with a quote for the laser cutting of the attached DWG files.
    Files:
    http://s000.tinyupload.com/?file_id=...60818712067197
    http://s000.tinyupload.com/?file_id=...18609789786115
    http://s000.tinyupload.com/?file_id=...36433331550637
    The material I would like to use is 3mm grade 5000 or 6000 (higher corrosion resistance) aluminium sheet.
    The work also includes countersinking of holes in one of the plates.
    The active layer when you open the CAD files is the layer that will be used for cutting purposes.
    cheers
    Glenn
    Feb 2014
    92
    Hi gbidwell
    Is the quotation still open? If yes, please let us know at this email [email protected] so that we can provide quoation. You also can upload drawing/3D file on our website (Proto Tree) for quotation. Thanks.
    BR
    /SL Wong
    Sales Manager
    Proto Tree LLC
    website: Proto Tree
    email: [email protected]
  1. Routing Aluminium sheet
    By kong in forum DIY CNC Router Table Machines
    Last Post: 05-06-2016, 08:44 AM
  2. Bending aluminium 7020 sheet
    By montifik in forum Bending, Forging, Extrusion...
    Last Post: 11-21-2011, 06:41 AM
  3. cutting aluminium sheet
    By johnalu in forum Waterjet General Topics
    Last Post: 08-19-2008, 10:02 PM
  4. Need help with holding down aluminium sheet
    By levelzero in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-06-2007, 10:32 PM
  5. Sheet Aluminium Cut Edge?
    By GalaticDan in forum DIY CNC Router Table Machines
    Last Post: 05-09-2006, 04:22 PM
