Hi guys,
Just wondering if someone could provide me with a quote for the laser cutting of the attached DWG files.
Files:
http://s000.tinyupload.com/?file_id=...60818712067197
http://s000.tinyupload.com/?file_id=...18609789786115
http://s000.tinyupload.com/?file_id=...36433331550637
The material I would like to use is 3mm grade 5000 or 6000 (higher corrosion resistance) aluminium sheet.
The work also includes countersinking of holes in one of the plates.
The active layer when you open the CAD files is the layer that will be used for cutting purposes.
cheers
Glenn
