Tips for cnc wood router spindle purchasing and maintenance.
Now, for cnc wood router, usually we use brushless spindle motor. So we need to consider the following issues when we choose.
1. Ask the supplier if adopting high precision bearing. If it is not with high precision bearing, after ong time high speed rotating, the life time of spindle motor will be affected. OMNI use high precision bearing on cnc wood router spindle whatever watercooling or aircooling spindle.
2 . Try to see when the cnc wood router spindle rotate at different high speed, if its sound is harmony.
3. If you prefer higher working effficiency, such as process wood etc, suggest you use spindle over 3kw.
4. CNC wood router spindle is easily get rusted if not under good maitenance situation. Light rust will not affect the suing, well, if you do not handle it for rather long time, then it will affect the cnc wood router spindle life time. How to move off rust? Two ways. One is to use tool to clean it. The other way is to use WD-40 sray on the spinlde, then use cloth to clean it after half an hour. This is a good solution.
