Hello! We have a new (used) LB15 on shop floor trying to get started. The manual states 'The LIMIT indicating lamp goes on when X- and Z-axis reach the set variable soft-limit position'. This is accurate when we started setting up this machine, however after changing the USER Parameter Variable Limits and changing Zero Offsets this lamp always stays on regardless of where slides are jogged. Any help on this would be quite appreciated! Thanks, Lisa
