586,033 active members*
3,559 visitors online*
    Sep 2012
    Counterboring for Anchor Fasteners
    Hi
    I'm creating a desk and in order to make it cheap I decided to counterbore the 8020 15 series myself(I also like to try new things). I have bought a counterbore JTS Machinery & Supply Co.
    and made a jig to the exact parameters provided by 80/20 however I have never "machined" anything before. The jig is made of angle iron and has a 13/16" hole the exact size I need to make into the 80/20. also I only need to go down .66" and half is only the actual T slot so there is not too much material to be removed. So how should I go about this I have a Dewalt 14.4V hand drill only 3 speeds.
    What speed?
    Should I even bother making a guide hole or just place into the jig and start?
    Also do I need to use a lubricant? Would prefer not to since then I have to clean all the pieces and wait to dry until assembly.
    Thanks for any help you can give me.
    exitium Guest
    Im not a machinist so take this with a grain of salt. drill speed is only part of the equation, you have the feed rate as well. Id guestimate around 800rpm with a pretty slow feed. If you jig has pretty high sides, which it probably should if your going to have straight holes, then a lubricant is probably not a bad idea and just about anything will do. I guess I would be most concerned, due to the extrusion shape and going through the T slot etc, would be the bit grabbing while handholding the drill.
  1. Counterboring Tele String-Through Ferule Holes?
    By 777funk in forum Musical Instrument Design and Construction
    Last Post: 02-15-2011, 12:32 AM
  2. Where to buy Anchor Danly
    By Apex Industrial in forum News Announcements
    Last Post: 09-10-2010, 02:18 AM
  3. Smart Fasteners are Dumb Fasteners
    By guru_florida in forum Solidworks
    Last Post: 05-27-2008, 04:44 PM
  4. Newbie needs help-counterboring
    By mikemechanic in forum MetalWork Discussion
    Last Post: 12-28-2007, 06:20 AM
  5. Counterboring carbide ?
    By DEVOR in forum MetalWork Discussion
    Last Post: 11-02-2007, 06:14 PM
