586,630 active members*
2,795 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
    Jun 2007
    65
    Laser Doctor Returns to answer your Co2 questions
    The Laser Doctor has checked in. Looking to answer your laser questions.
    Sep 2005
    1195
    Laser Doctor,
    Why a new thread?
    Jun 2007
    65
    The Doctor pressed the wrong button this morning. Sorry.
    Oct 2007
    385
    Newbie question--What is the purpose of the gold on the focus lens? It is pretty much worn off of the focus lens that I have, but it still cuts just fine. Should I be purchasing another one?
    Milt
    Jun 2007
    65
    It's not gold. This is an Anti-Reflection coating that the manufacture puts on both sides of the lens. The lens without the AR coating will reflect 4% of the laser power, 2% each side of the lens or transmit 96% of the laser power. With the coating the laser beam will reflect 1% or transmit 99 % of the power.
    Dec 2006
    76
    In the same vein. Why is it necessary for the mirrors to be gold plated? Some people have cut mirrors from hard disk platters and claim comparable results.
    I'm curious about that as well now. After reading your question, I sought out information about using an old hardrive for mirrors and found this great tutorial: DIY Laser: Get Your CO2 Laser Mirrors for FREE
    Oct 2007
    385
    I am using nothing but mirrors made from a hard drive and they work just fine. I have a bunch of them that I have cut out.
    Milt
    Jun 2007
    65
    I never have seen this. But the answer is simple. The mirrored surface is silver plated, not a reflective as true laser coating. This also sometimes appears as gold plate. Also works as a reflector. Seem like a lot of work to me
    Oct 2007
    385
    It took me approximately 1 hour to make 9 lenses out of one hard drive. This actually amounts to 19 lenses, as both sides are useable. I used my homemade CNC router to cut out the 20mm discs. 18 mirrors would probably cost over $300, they cost me just one hour of my time. Worth it for me. Oh yes, I also had to make a spacer ring, as the lenses are only about
    1mm thick.
    Milt
    Jan 2011
    Laser Doctor, what would be the gas mix on an 80 watt sealed glass tube laser,
    Somthing i have always wonderd ,
    And are these tubes under a slight vacuume?
    Regards
    Jun 2007
    65
    The gas mixtures are kept highly secretive. There are numerous combinations depending upon the laser type DC or RF. The base mixture is Co2/N2/He.
    The Laser Doctor
    Jun 2007
    65
    Yes laser tubes are under vacuum, just like a light bulb.
    Sep 2012
    LD, whats the preferred glue in thin plywood that makes for easiest cutting. Thanks
    Sep 2012
    I need help
    Laser Doctor,
    I would appreciate any help you can offer. I have a 40 watt DC-KIII laser engraver (made in china). The problem is that all of the sudden I cannot regulate the cutting power with the "current regulation" knob. It will work with the test button. When I try to engrave something the current indicator mostly stays around 4-5 regardless of how much I turn up the current regulator knob. Does this sound familiar?
    mrbbsc
    Jun 2007
    65
    It sounds like the current regulator has stopped working. You basically have the one setting without adjustment with the power control. The test button is just a signal to fire the supply. I assume like a test fire button. I do not have any experience with this Chinese power supplies in general. I have seen them in different application and their quite cheap. I assume you can purchase a new one for little money. Probable your best bet.
    Mar 2008
    42
    LD, is it feasible that a 150W glass tube CO2 laser with oxygen assist would cut 1mm thick steel sheet-metal? I don't mind stainless steel or aluminium, just steel sheet.
    Regards,
    Fernando
    Jun 2007
    65
    Wow, what a great question. I honesty don't have an answer for you. Maybe someone in the community can answer it. Now, I have seen many laser cutters of sheet metal. However, they usually start around 5oo watts to 10 KW with oxygen or air assist. The idea is to get the metal red hot first, in one spot, and then start cutting.
    Sep 2012
    Laser Doctor,
    I'm not totally convinced it's a bad current regulator because when holding down the test button and turning up the current regulator knob at the same time the current meter responds accordingly.
    mrbbsc
    Dec 2008
    25
    Quote Originally Posted by fmederos View Post
    Regards,
    Fernando
    It looks like G. Weike has a couple systems that can do 2 mm.
Page 1 of 2 12
  1. Laser Doctor Returns to answer your Co2 questions
    By Laser Doctor in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-02-2013, 07:06 AM
  2. Camshaft doctor
    By AirChunk in forum I.C. Engines
    Last Post: 09-15-2010, 04:50 AM
  3. Replies: 0
    Last Post: 04-15-2009, 10:27 PM
  4. Can you answer the questions in these pictures?
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-03-2007, 09:36 PM
  5. I can answer your Rhino questions
    By Dan B in forum Rhino 3D
    Last Post: 07-02-2004, 10:33 PM
