Hi all, I bought a machine for engraving Chinese steel is this:
The spindle motor:
The problem I see is the power consumption of 1.0kW uses 4 servos, spindle is 5.5kw at 360V and told me the salesman that used a transformer to convert 220v to 380v three phase . It should be noted that in my country is 220V three phase
My question is if the machine worked well using the corrriente transformer, or maybe I should use smaller engines 220v directly but unused current transformer.
I need advice, thank you very much
