Hi Guys,
I am in the same position as everyone starting out in the CNC Hobby game gets to at one time or another. What size motor.
I worked my way through here off and on for weeks and are still as confused.
Essentially I have a custom wood made Router with 1605 lead screws on all axis.
With router attached it will be about 30kg sitting above the bottom axis with gantry and Z axis etc. I have about 600mm x 450mm x 130mm travel on the machine
I don't know how fast I need to go, I dont know the cutting forces of the material I want to cut. Mostly ply and custom wood, but I would like to cut some sheet Ali as well. I cant find a really clear beginners guide to motor selection and have been tossing up between Nema 23 270 oz-in and 425 oz-in
I was planning to run them on 48V as the drivers I plant to use DQ542MA or CW5035 from Aliexpress stores will handle up to 50v. If the supply I get has a pot I may de-rate it a little to be a little safer.
If I go with the 425 oz-in units could I be to big? One of the models I have found has 6.8 inductance rather than 9 so that must help speed a little if using 48 volts if the formula I have used to select optimum voltage is correct.
Sorry really just another of those what size posts, but just really struggling to decipher the vast amount of information in these forums.
Regards Blair
