**Hi everyone,I have started to configure Oi - TD system with x,z and ATC as geometric axes and 2 spindles.I configured the geometric axes and moved it but i was unable to move the spindles although the spindle move bit is getting switched on through logic(G70.4,G70.5).
So can anyone has the parameter list required for the configuration of spindle along with second encoder configuration for spindles..Also the total no of controlled axes in Oi-Td system is 5.Does it include the spindles or not??
** Secondly we have been using seperate ALM for second spindle in this machine.The problem is the ALM does not switch on to get to servo state since the CX3 slot in ALM is not supplying voltage inorder to boost the contactor..So waiting for ur fast replies which can help me a lot..
