586,724 active members*
3,805 visitors online*
    Oct 2005
    186
    Cam/Cad DXF units question
    I have a question again on the units of a DXF file. Didn't someone say there are no actual units such as inches or mm for a DXF file? Its just how your software selects to view it? So if my software says a line is from 0,0 to 20,20 and I select inches for the units in a viewing software, its going to show that line as 20 inches?
    In my app I am writing I am drawing lines using pixels. So a letter may be 150 pixels tall. When I save it as a DXF and then view it in a program like SheetCam and select Inches as the units, the letter is HUGE! It shows it as 150 inches tall.
    So do I need to scale down the line lengths if I want it to be in inches? And if a letter is showing 150 inches tall based on the pixels, I need to divide every line by atleast 10 or more. And if I want to make it be measured in MM then I would hardly divide it at all.
    Did I answer my own questions? My brain is so tired from working on this all day!
    Warren
    What I'd do is figure out how tall the largest letter drawn is in pixels. Then give the user a box for height. Then just divide the requested height by the pixel height to get the actual height.
    Oct 2005
    186
    For testing I divided each number by 10 and it reduced it down to 14 inches. Now I just need to determine what number to divide by to match the ruler setting for both Inches and MM.
    Gerry, I'll send you a copy when its done. It may not be as fancy as some of the other software but for my first cnc application I think its coming along okay. After this version I may work on a carving type application similar to vcarve and others.
    Warren
