586,075 active members*
4,112 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Poor Surface finish on interior corners
    Oct 2006
    85
    Not really a mastercam problem but thought I'd ask here since I use mastercam to program.
    How do you deal with vibration marks on the interior corners of a pocket where you're hanging a small tool out.
    What strategies have worked for you?
    I'm currently working on a part with 1.75" deep pockets with internal corner radius' of .125"
    For shallow pockets, using a smaller size end mill works well, but when going 7xD I need to use the beefiest tool available and going down to a 3/16 tool doesn't see feasible....but maybe it is...I haven't tried.
    I guess this isn't limited to inside corners but that's where vibration is most prevalent.
    Thanks for the input.
    Aug 2009
    684
    The vibration is caused by the massive increase in radial cutter engagement in the corner. You could either drill/plunge the corners out first, or mill each corner in multiple passes, gradually decreasing the corner radius each time. You would also have to use multiple axial cuts as opposed to a single cut at finish depth.
    If you have a 5 axis machine, angle the part so that only the end of the cutter is in contact with the part and that will have the same effect.
    All these strategies are more time consuming I'm afraid....
    DP
    May 2004
    4519
    Quote Originally Posted by christinandavid View Post
    DP
    +1
    Also try necked down tools with minimal flute lengths. Sometimes you can get away with depth cuts with minimal steps showing.
    Apr 2005
    713
    Reduced Shank 3/16 3 Flute End Mill Finisher 3.5 long X .157 Shank MariTool
    These tools work really well for stuff like this. I like them for finishing, but they work just as well for roughing. Leave .004 - .006 or so for this tool to finish, step it down around .300" and feed it at .0008 - .0009 IPT and you'll be happy.
    There's just no way to stop chatter in the corners other than a smaller tool.
    Dec 2008
    3109
    DP
    Another suggestion to add to this one
    - rough the shape as you normally would
    - fit larger rads ( say R1/2 ) on the finishing contour's internal corners, to keep the larger tool ( say a 5/8" cutter) away from them, this machining should not add any time, speeds / feeds can be quite reasonable
    - finish the corners as previous described ( plunge out with a 1/4" cutter-use a peck cycle to eliminate deflection ), then contour with a 3/16" using depth cuts ( say 0.080" depths) , ( these are the added time operations )
  1. Poor quality finish
    By NylonAdmiral in forum MetalWork Discussion
    Last Post: 04-27-2012, 06:05 PM
  2. poor edge finish on v carved plywood
    By gateman in forum DIY CNC Router Table Machines
    Last Post: 04-22-2012, 05:40 AM
  3. Poor finish
    By LLDesigns in forum Benchtop Machines
    Last Post: 07-02-2011, 01:56 AM
  4. poor surface finish
    By sinha_nsit in forum CNC Tooling
    Last Post: 02-17-2010, 04:48 AM
  5. Poor surface finish
    By pmsmichelle in forum Mastercam
    Last Post: 02-05-2010, 03:54 PM
