586,281 active members*
3,806 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Memory board/battery alarm 4035
Results 1 to 5 of 5
    Aug 2011
    Exclamation Memory board/battery alarm 4035
    I have a OKUMA controller OSP700M. We just replaced the battery after we got a 4035 battery alarm. Long story short the Alarm is still on the screen and it has a new battery. So what should I be heading next in fixing this machine.
    Jan 2009
    74
    You need to get a 'battery connection floppy' from your local dealer. This disk resets the battery date timer.
    Oct 2010
    Had this happen on LU25 osp 7000 not long ago, didn't get normal change battery warning, just alarm that battery was dead. Battery was good,only 2 years old.
    Had battery reset disc but ended up having to reload software.
    Oct 2012
    Get
    the battery change diskettes from your Okuma rep.
    You will need three, one for Battery, one for System parameters and one for User parameters. the change procedure comes with the diskettes, about $100.00
    Jun 2014
    Re: Memory board/battery alarm 4035
    Dose any one out there have a copy of the battery reset disc? Can you send me or better yet email a copy $$?
  1. Memory backup battery
    By Captdave in forum Fagor Automation
    Last Post: 07-31-2012, 08:49 PM
  2. 4035 Alarm-D
    By energyzer in forum Okuma
    Last Post: 05-16-2012, 12:59 AM
  3. Memory Retention Battery ?
    By Bruce_Mowbray in forum Haas Mills
    Last Post: 01-22-2010, 09:16 PM
  4. changing battery on memory board.
    By rdf7 in forum Okuma
    Last Post: 01-12-2010, 07:51 PM
  5. ge mark century 550 memory battery
    By Daniel Wilcox in forum Controller & Computer Solutions
    Last Post: 11-15-2009, 06:57 AM
