586,944 active members*
2,130 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Iregular round shapes of large holes
Results 1 to 3 of 3
    Sep 2012
    I'm using LPKF Protomat 93s machine for pcb drilling.
    Whenever it uses 2mm contour router for drilling larger holes,there are ireegular shapes of holes.dont know the why it is happening,previously it was working fine.
    I need help wana know the possible causes.
    Dec 2004
    1137
    I don't have this machine, but based on your description:
    * Could be the Z axis is loose allowing for slop/movement when the resistance of the material is too high.
    * Could be that the router bit is flexing too much
    * Are you using the vacuum and pins to make sure the PCB does not shift?
    * What is your depth of cut when you try to cut these holes? Are you doing it in one pass are multiple? How thick is the PCB?
    * Are the holes in the right location?
    Sep 2012
    Re: Iregular round shapes of large holes
    Visit the link below for more information and help.
    printed circuit board manufacturer
  1. Selecting large amount of holes X4
    By MiechH in forum Mastercam
    Last Post: 03-29-2012, 07:59 PM
  2. holes not coming out round
    By badassdevil in forum DIY CNC Router Table Machines
    Last Post: 04-18-2011, 02:06 AM
  3. Plate Beveling round holes? Plasma or Oxy/fuel
    By WSS in forum Waterjet General Topics
    Last Post: 01-07-2011, 07:55 AM
  4. Drill press, centering holes in round stock
    By zeeman69 in forum Uncategorised MetalWorking Machines
    Last Post: 06-03-2010, 10:18 AM
  5. Round parts with holes on OD
    By CharlesM479 in forum Solidworks
    Last Post: 07-09-2007, 03:08 PM
