586,096 active members*
3,012 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 3d cutting with flycutter
    Feb 2012
    19
    I'm not sure where I should put this thread, if this is the wrong place sorry. What I'm trying to do is cut a wave pattern into an mdf panel.I want to use a 1.875 Inch fly cutter to cut the waves to save time from using a ball mill. The waves are 0 to 3 degrees spaced every 4 inches apart. I'm using a 5 axis router and rolling the B axis with the waves, The fly cutter cuts fine on the sallow wave but on the steeper inclines it leaves a strip of material in betewn cuts. Can anyone help me come up with a reason for this Thanks.
    Nov 2006
    19
    might have to do with the diameter of your tool not being able to reach or cut the material. not 100% sure on your strip of material being left. got a pic?
    Apr 2003
    3578
    are you using mastercam to program your 5x router and also would like to see a picture of what you are cutting . we need more info.
    Cadcam
  1. Taig Flycutter
    By 5artist5 in forum Taig Mills / Lathes
    Last Post: 05-20-2013, 01:43 AM
  2. Any info on the TTS Flycutter?
    By cheetahcnc in forum Tormach Personal CNC Mill
    Last Post: 12-30-2012, 06:08 AM
  3. Flycutter tool bit for aluminum?
    By lcvette in forum Benchtop Machines
    Last Post: 02-06-2012, 12:41 PM
  4. Flycutter for Proxxon MF70
    By dash2099 in forum Benchtop Machines
    Last Post: 11-02-2010, 02:55 AM
  5. Proper use of a flycutter
    By JWeb in forum Benchtop Machines
    Last Post: 08-20-2010, 07:12 PM
