586,071 active members*
4,360 visitors online*
IndustryArena Forum > CAM Software > Esprit > Need help editing asc post file for Esprit.
Results 1 to 9 of 9
    Feb 2011
    My lathe post is posting out in feed per inch, I need it to post feed per rev.
    I add chip feed rate according to Esprit Help and no go. this is really no good.
    2932
    Quote Originally Posted by Den Man View Post
    What version of Esprit are you running?
    Are you sure the Feed Unit in the operation is set to Per Revolution?
    Feb 2011
    Hey dcoupar, I'm using Esprit 2009 and Per Revolution is set for .002 Esprit help says "Use the formatable code keyword CHIPFEEDRATE". I edit the ASC file and still get feed per inch. This is for a TL-2 HAAS Lathe.
    2932
    I no longer have access to E2009, but I just checked this one for a Haas mill turn in E2012, and it outputs G97 and correct fpr. Rename it to a .asc extension and see if it works in e2009.
    Attached Files Attached Files
    Feb 2011
    ASC file-TL-2 HAAS Lathe.
    Thanks dcoupar, this works fine.
    Jan 2012
    8
    did you get this fixed?
    Feb 2010
    4
    Re: Need help editing asc post file for Esprit.
    Maybe a stupid question , dou you have set the feed rate in the general setting on feed per rev or feed per minute , where is this happening specific cycle driling , od roughfing ? let me know to check if I can help you
    Aug 2014
    Did any one have post for cnc swiss screw machines ASC
    EMS file machine set up?
    For stars tsugamis or Citizens?
    Nov 2017
    6
    Hello
    I'm starting to work with Esprit CAM
    Any of you have any Esprit cam post processor for swiss lathe?
    Possible to send by email - [email protected]
    I would really appreciate
    thank you
  1. Editing G-Code File
    By Kiwi in forum G-Code Programing
    Last Post: 06-17-2013, 10:59 PM
  2. opeing G code file for editing
    By billwann in forum SheetCam
    Last Post: 11-18-2011, 04:31 PM
  3. Editing Solid Models In Esprit
    By thebowman in forum Esprit
    Last Post: 01-24-2011, 01:19 AM
  4. Editing FANUC GPP File
    By almo0797 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-13-2009, 11:31 PM
