586,060 active members*
4,328 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Gcode issues using Artcam with a thermwood machine/newbie
    Aug 2012
    So here's the deal:
    I'm pretty much brand new on this Thermwood Machine, and am using artcam as my toolpath program. I'm looking to run multiple rounded rectangles out of a 1.5" board of mdf.
    My daylight values are not accurate and my spoilboard is screwed to my table board, along with the inability to flycut an uneven table, so i have modified my gcode the artcam produces a bit so i get the results i want. I have the z-shift to adjust for this, along with giving me the ability to aircut to test the program. I've run a couple of test programs and the other day i was cutting a similar program completely fine.
    Today i adjusted the toolpaths for a 1.5" board of mdf with a ramp in and 2 passes. I thought i set it up correctly and sent the file to the machine, but when i ran the part, it gets to the line after M31 and just stops dead. Spindle and all. No E-stop, no error message, just stops.
    Is there some conflicting code in my file? I've compared it to other files and it seems to be similar, no noticeable differences or wonky commands.
    So what's my problem?
    Here are the lines of code leading up to the problem:
    (Program Name-florsheim)
    M999
    G90
    G92X.5Y-12.25 F200
    SET ZSHIFT=3
    T1 M3
    S15000
    (0.500 inches dia. slot drill)
    G00 Z3.0000
    G01 X0.2500 Y12.0000
    M31
    G00 X0.2999 Y1.1397 Z2.0000
    G01 Z0.2500 F200.0
    What does M31 do on a Thermwood?
    73
    The M31 code pauses the program until the spindle gets to the appropriate speed.
    I don't see anything wrong with the code.
    Do you have the spindle rpm adjustment at 100%.
    If you don't get it figured out call Thermwood's tech support. They are very helpful and will trouble shoot the problem for you.
    Zach
    Apr 2005
    175
    Gcode
    Does not the G01 line need a feed rate?
  1. Thermwood GCode Problems with Artcam /Newbie
    By mike.anthony in forum ArtCam Pro
    Last Post: 09-29-2012, 03:25 PM
  2. Gcode issues in MadCam
    By zevenwolf in forum MadCAM
    Last Post: 09-20-2012, 10:30 AM
  3. 2mm Al. + Artcam + newbie = horror
    By MGPL in forum MetalWork Discussion
    Last Post: 09-24-2011, 12:29 PM
  4. PLease help - gcode newbie
    By scotty1 in forum Uncategorised CAM Discussion
    Last Post: 03-07-2010, 12:03 AM
  5. ThermWood C67Dt 5 Axis Machine
    By lerma303 in forum Commercial CNC Wood Routers
    Last Post: 04-30-2008, 02:53 PM
