586,103 active members*
3,651 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Control/Windows 7 Issue's
Results 1 to 16 of 16
    Jan 2010
    81
    Hey guy’s,
    We just moved our PC’s to Windows 7 64bit and had problems getting the communications working to our VM3 (we also have a VF1 but that was fine). After talking to our local HFO guys I got the hook up ok but didn’t realize that there was a deeper issue.
    If I sent a file to the HDD on the VM3 from my win 7 PC the data multiplied somehow.
    Sending from an XP PC is fine and again this was not a problem sending to the VF1.
    After some google research I found that this has been an issue for many many people.
    I was wondering if anyone has found a fix for this issue.
    VM3 has M16.02a control software installed in 2009
    VF1 has M13.12f installed in 2005.
    May 2004
    4519
    My solution has been DO NOT use Windows 7.
    May 2006
    183
    Have you tried running whatever program you're using for transfer in compatibility mode?
    Jan 2010
    81
    Quote Originally Posted by Cory View Post
    Hi, I'm not actually using a program to transfer so can’t use compatibility mode. It's just drag and drop from one HDD to another across a network.
    As I mentioned, this works perfectly well on the VF1. It's just the VM3 I have a problem with.
    Jul 2007
    52
    Same problem here for many years since changing to windows 7. Our HFO is working on it without much joy. I'll post back when a solution is found.
    Andrew.
    VF3+TRT210, VF3, VF2+HRT160, VF2SS+TR160, VF2SS+TR160, VF5TR, VF5TR, VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS
    Jan 2010
    81
    Quote Originally Posted by omy005 View Post
    Andrew.
    I suspect we have the same HFO. Is it George?
    I’ve got to say I’m a bit frustrated that this is still an issue so long after win 7 was released.
    Jan 2010
    81
    Andrew.
    15362
    dengo
    I think if you change your computer to 32 Bit to match the Haas control, most times everthing will work as it should, or you can use XP compatible mode in wondows 7 as well
    Mactec54
    Jan 2010
    81
    dengo
    But that doen't explain why the VF1 is ok and the VM3 not.
    Thanks for the suggestion though.
    15362
    dengo
    Yes it might do you have the hard drive option on the VF1 The same as you have on the VM3
    Mactec54
    Jan 2010
    81
    Yep,
    Both have HDD's and ethernet connected.
    Both worked perfectly well before we got new computers with win 7 64bit on them.
    Cheers
    15362
    dengo
    The hard drive option is not just a hard drive added to the system, they are a complete stand aloan computer, I think you will find that there is something wrong with this computers configuration, it has nothing to do with the control software version, as this computer is compleatly separate, from the main control computer
    Mactec54
    Jan 2010
    81
    dengo
    So any clues how to fix it then?
    Cheers
    Jan 2010
    81
    Smile Solved
    Just a heads up on what I did to fix this problem.
    We tried various Haas control software upgrades together with a software/firmware upgrade for the floppy drive.
    The combination that worked was the original control version that I listed earlier together with the updated floppy software/firmware and some gentle tweaking of the network settings on the machine.
    Works perfectly now and although it took a little while to dial in on it’s a pretty simple fix.
    Thanks to the guy’s at our local HFO for their help.
    Feb 2010
    1184
    Quote Originally Posted by dengo View Post
    Thanks for the follow up! It's always nice to hear what the solution was to a problem. Glad you have things sorted out.
    May 2012
    The issue is the main-con processor. It has a compatability issue with 64bit which is what Windows 7 runs. There is currently no fix, and none coming anytime soon.
  1. Talking to my Haas via Windows 7 and Ubuntu
    By MarkSerbu in forum Haas Mills
    Last Post: 05-31-2013, 10:09 AM
  2. Possibilties of Virus from Windows to Haas control
    By fattybean in forum Haas Mills
    Last Post: 08-13-2009, 06:07 PM
  3. cnc control software for windows xp
    By Ralph Burge in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-29-2008, 01:21 AM
