586,094 active members*
4,090 visitors online*
    Nov 2009
    Draw in MM or Inch?
    If I draw in millimeters, will it be a hassle for me when I'm milling with Inch bits, or going to Cam?
    May 2004
    4519
    It is not a hassle to me to switch between the two systems. Your mileage may vary.
    Jun 2007
    3757
    I use both types of machines interchangeably. My brain doesn't even notice.
    Half the measuring equipment is metric and the other half imperial.
    I like meters and hate newtons. I don't care about gravity, nor should I need to cancel it out.
    Apr 2010
    294
    I also draw in millimetres, and my Mach3 is always set up to work in these units. But CamBam has no difficulty with inch-sized tools. And the resulting toolpaths are perfectly adjusted to accomodate the tools.
    Nov 2009
    Your answers have really helped. Thank you so much!!!
  1. Replies: 4
    Last Post: 09-11-2012, 10:30 PM
  2. 0.005 inch cut???????
    By emh114 in forum Uncategorised MetalWorking Machines
    Last Post: 04-08-2010, 09:42 PM
  3. Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-02-2009, 11:38 AM
  4. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 03:27 PM
