586,103 active members*
3,726 visitors online*
    Dec 2010
    15
    3 View Drawing
    Hi. I am still new to BC. I use it on my 2 axis mill and like it. So I usually just draw in 2d top view. I like printing drawings with the standard 3 views. But I have not found a way to draw in 3 views (ie, top front, right).
    Any help would be appreciated!!
    Also, I can't seem to get the 3D drawing to work. I followed a few tutorials, and thought I did it correctly, but extruding something did not work.
    I have the standard 2 axis mill V24, but I was under the impression that I could still draw in 3D?
    Any suggestions?
    Thanks!!
    Dec 2011
    361
    You are able to draw in 3D as the CAD side is completely separate from the Mill side. As far as the 3 View option, that would be something that would require a drawing module, something that at this time BobCAD does not offer.
    Dec 2010
    15
    Thanks Sean. Are there any 3D drawing tutorials available?
    Scott
    Dec 2011
    361
    Unfortunately we have no freely available videos. There are drawing videos for Level 2 and 3 Support members and located on the training videos that are sold individually.
    Jun 2008
    1838
    This might help
    See image below, is this something like what you want ? ? ?
    If so then the attached file might help a little
    Regards
    Attached Files Attached Files
  1. Drawing in Y-Z view
    By rozon in forum BobCad-Cam
    Last Post: 12-26-2009, 05:35 AM
  2. Replies: 13
    Last Post: 10-02-2009, 04:32 AM
  3. HOW TO SET X AND Y AS TOP VIEW
    By atlantic23 in forum Solidworks
    Last Post: 06-02-2009, 12:11 AM
  4. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
  5. exploded view drawing?
    By busted bit in forum Bridgeport / Hardinge Mills
    Last Post: 04-30-2008, 06:33 AM
