586,103 active members*
3,827 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > ES-L6 Alarm D MCS resolver
    Sep 2008
    93
    lathe ES-L6 II control OSP-U10L
    871-20 alarm D MCS resolver
    in the spindle drive appears 18
    i have changed the motor and the machine run ok
    the problem is the motor, (the resolver)
    how to check the resolver
    what I can do?
    this is the date of the resolver
    brushless resolver
    type: 101-7801-8
    input 10v 8kHz
    sanyo denki co. ltd
    saludos
    Jan 2009
    74
    you can ohm out each of the 3 coils in the resolver. They shouldn't be open or short. next best would be putting a meter on them and look for an AC signal when rotating the motor.
    Sep 2008
    93
    Quote Originally Posted by old timer okuma View Post
    I have reviewed the 3 colis
    red - black 30.5 ohms
    yellow - blue 30.5 ohms
    white- brown 26.9 ohms.
    but in the rotor there is another coil, this coil is damaged.
    where i can buy this resolver?
    Jan 2009
    74
    sounds like all three coils are good. There is no way to check the rotor (that I know of). do you have AC voltage going to the resolver? and feedback when voltage when you spin the motor? The rotor may not be center on the motor shaft, this can be from bad bearings or if someone has been in the motor. The resolver on Okuma's are all the same since the first AC motors, so should be easy to get one from your local dealer.
  1. Resolver
    By SuperFlyLoser in forum Servo Motors / Drives
    Last Post: 06-21-2012, 09:21 PM
  2. DC Servomotor Resolver
    By davisboys in forum Fadal
    Last Post: 11-26-2009, 12:07 AM
  3. C-axis resolver
    By EPTech in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2009, 02:04 PM
  4. Encoder vs resolver
    By zoeper in forum Servo Motors / Drives
    Last Post: 04-25-2006, 06:42 PM
  5. Encoder or Resolver?
    By bcromwell in forum Stepper Motors / Drives
    Last Post: 07-23-2005, 03:26 AM
