If anyone has a metal version of the upper drive gear that meshes with the drive motor I am in need. As the plastic one stripped all the teeth off.
Thanks Dennis
Thanks Dennis
You might consider a belt drive conversion.
G0704 Belt Drive
Does it require a new motor, or do you use your old one.
You can use the stock motor with a belt drive, but most people opt to swap it out for a treadmill motor. Keep in mind, if going by Hoss's plans, there are separate prints for using the stock motor vs. a treadmill motor. Also, a conversion won't be much help to you if you don't have access to another mill to make conversion parts.
Only one mill, anyone sell a reasonably priced kit. Or want to make me one.
You can order stock parts from Grizzly:
http://www.grizzly.com/products/G0704/parts/2
