Originally Posted by
109jb
Not sure how the flashcut system works, but it should have settings for max velocity, an acceleration/deceleration. This will greatly affect performance. Also, if the machine had the gibs too tight, or if there is some other mechanical binding the that will affect it too. 20IPM is really slow. I think mine is slow at 70 IPM.
I assume the Z axis just operates the quill. If so, is the quill lock tight or loose and how tight is the spring? My benchtop uses the quill for z too and I have the quill lock just barely snug to take up slop, but not cause too mich drag. My spring is reversed so that the sping provides down force on the tool, so the motor is fighting the spring as z goes positive. Again, i have the spring pretty loose so that it just provides a little down force but not too much.
Let us know how the machine is set up and you will get better answers. For example: Ballscrews? Direct drive from steppers to screws? How is quill hooked up? Any mor info on steppers like oz-in rating, power supply used, what drivers, etc.
