586,119 active members*
3,596 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Rotary broaching on turret lathe
    Feb 2012
    I have a W&S 2A m-2519 turret late, I am wanting to rotary broach Internal and external 17mm square or double square with this machine, will I have enough end force to do this process on carbon steel 1045? If there is more info needed please advice me. This is my first post here, but have lingered for some time.
    Nov 2010
    32
    Stimey,
    Do you know what kind of thrust pounds your machine is capable of? A 17mm square is a very large size for rotary broaching and will likely create at least a couple thousand pounds of pressure. There are quite a few factors that determine this, and if you can optimize them all you may get it to work:
    1. Pilot hole size must be oversize as much as possible.
    2. Room for chips in the hole.
    3. Minimize depth of the form.
    4. Undercut for chip break-off if possible.
    5. Chamfer to the sharp corners is required.
    6. Eliminate sharp corners to reduce chip size.
    Feb 2012
    Yes I agree this is not practical, I spoke with Slater the other day and they have the same opinion. The rotary broaching approach is really cool, I guess there is limits to everything. Thanks for the input.
  1. rotary broaching swiss
    By elsanch in forum MetalWork Discussion
    Last Post: 09-30-2019, 08:53 PM
  2. How Rotary Broaching Works
    By SwissType1 in forum Videos
    Last Post: 03-27-2012, 08:01 PM
  3. Rotary Broaching
    By rhino in forum MetalWork Discussion
    Last Post: 09-16-2011, 07:15 PM
  4. Rotary Broaching
    By inertialabs in forum Haas Mills
    Last Post: 12-25-2010, 04:45 PM
  5. Rotary Broaching Chip Accumulation
    By peter@slater in forum Videos
    Last Post: 06-25-2009, 01:35 PM
