586,645 active members*
2,720 visitors online*
IndustryArena Forum > CAM Software > Mastercam > HOW TO CHANGE XFORM DEFAULT SETTINGS
    Jul 2008
    138
    ANYONE KNOW HOW TO CHANGE THE XFORM DEFAULT SETTINGS?
    I HATE EVERY TIME I HAVE TO ROTATE OR ANYTHING ELSE, I HAVE TO CHANGE IT TO MOVE, AND NOT COPY. REALLY ANNOYING.
    May 2004
    4519
    Did you check under Configuration > CAD Settings > Preview >Maintain? You might want to spend some more time reading the help file (press F1 key). Almost all the information is in there.
    Jul 2008
    138
    HEY TXCNC, HOW YOU BEEN?
    NO I HAVENT LOOKED UNDER CONFIG YET. I THOUGHT IT WOULD BE UNDER CUSTOMIZE. BUT THOUGHT I WOULD CHECK HERE BEFORE I STARTED CHANGING ****. I WILL LOOK INTO IT TOMORROW. THANKS FOR THE REPLY. GOOD TO SEE YOUR STILL HELPING OUT.:wave:
    Apr 2003
    3578
    I always have to ask what version as there are changes over the years. as it is not the same from say v8 and v9 then again from MC-X to MC-X6
    Also the newer versions will remember your settings thru out your session once you use it once. there are no direct option for setting to Move vs Copy.
    Cadcam
  1. Geometry and xform default to Z0
    By Matt@RFR in forum Mastercam
    Last Post: 08-21-2012, 07:41 PM
  2. saving default tool path settings
    By Joesph Jackman in forum Mastercam
    Last Post: 03-21-2012, 05:39 AM
  3. Sinumerik 810M changing default settings
    By ignace in forum SIEMENS -> GENERAL
    Last Post: 10-07-2010, 05:18 PM
  4. Preferences / settings default
    By DIFF OVER in forum BobCad-Cam
    Last Post: 09-06-2010, 09:26 PM
  5. Mastercam 9.1 default settings
    By Fatty in forum Mastercam
    Last Post: 06-29-2006, 05:04 AM
