586,069 active members*
3,847 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Planar finishing issue.
    Nov 2008
    43
    The finishing passes sometimes pass through areas which are not supposed to be cut. This seems to happen only when I use Regions. Here's a screenshot of the simulator which clearly shows the problem:
    For the example above, I had set up regions so that only the rope pattern was cut. The roughing pass worked without any problems. The z levels also worked. It was during the Planar finishing that the errors are made.
    Any help would be greatly appreciated.
    Jun 2003
    2103
    send me your email via pm.
    I help Joakim with a bit of support here in the US,
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Nov 2008
    43
    @turmite: Done! Thank you.
  1. Slice Planar Question
    By vpl in forum BobCad-Cam
    Last Post: 08-13-2014, 07:23 PM
  2. Planar Finishing problem
    By Zuckerbäcker in forum MadCAM
    Last Post: 04-17-2011, 04:21 PM
  3. Can't highlight drawing for inside planar finishing
    By williamsmotower in forum MadCAM
    Last Post: 12-13-2010, 11:36 AM
  4. slice planar
    By skippyfix in forum BobCad-Cam
    Last Post: 08-14-2009, 09:01 PM
  5. wont planar
    By racefast in forum BobCad-Cam
    Last Post: 02-20-2008, 02:05 PM
