586,655 active members*
2,881 visitors online*
IndustryArena Forum > CAM Software > CamBam > Moving CAMBAM to a new PC?
    Jul 2008
    498
    I'm migrating over to a new computer and need to move CAMBAM while keeping all my styles etc intact. What is the best way?
    Old PC was XP pro, new is Win7-64 professional. I have about 10 days left of having both computers fully functional.
    Cheers
    Dougal
    My X2 CNC Brain Build: http://www.cnczone.com/forums/showthread.php?t=61345
    Gecko G250 wiring errors: http://www.cnczone.com/forums/showthread.php?t=68960
    May 2007
    428
    I don't work with CamBam myself, but just a quick browse to help you out:
    Your license file is called CamBamPro.lic and should be located in the same folder that CamBam is installed in.
    This is usually...
    C:\Program Files\CamBam plus 0.9.8
    You just need to copy this file into the CamBam folder on the new machine.
    Dolphin CAD/CAM Support
    Apr 2010
    294
    I've had a browse about on my PC and have found relevant looking files in the C:\Program Data\CamBam plus 0.9.8\ folders there are subfolders under here that seem to contain the sytle definitions, tool libraries etc.
    Jul 2008
    498
    Thanks guys
    I had to find and copy the .xml standards files from the allusers/application data directory on the xp machine to the equivalent program data/cambam directory on the win7 machine.
    All my styles are now there.:cheers:
  1. Z AXIS - Moving bearings or moving rails ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 02-28-2012, 06:22 AM
  2. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  3. moving a part in the cambam field
    By wantsout in forum CamBam
    Last Post: 10-23-2008, 05:11 AM
  4. Discussion of moving table vs moving gantry
    By rkremser in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 10:59 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
