CNC simulator does not seem to be sending any petrol file through when requested?
It says it is sent, but nothing shows up, anybody else seeing this?
Al.
Al.
Albert E.
Take a look on sites FAQ, it may answer your question (link below). Also make sure, when you are updating, that you tick the 'Agree to Licence" box. The other note is that you have to download a new driver if petrol refill does not show up on screen. I just went throught the process and I received the email updated number within a minute.
FAQ
Strange? It did not like my regular email address that I have used since day one with it, must have put a block on it?
One of my others worked OK.
Al.
Albert E.
I got a new petrol code but don't have a window in the dialog box to place the refill code. In the email it says I need to install the petrol driver update located on the download page. It appears that cnc simulator doesn't list the petrol driver update on the download page anymore. By any chance does anyone have a copy some where so I can continue to use my old version?
Thank you,
dale
cnc(at)outagas(dot)com
I have the older petrol number version, I found I had to use one of my Gmail or Yahoo mail addresses to receive the new code.
For some reason my regular email blocks it, although it is not in the filters?
On the page for the Petrol download there is an option for the legacy version of the code.
Al.
Albert E.
their 'protection' method has major problems. it is easier to run my crack patch which just removes some registry B.S. and then re-install it. Using the batch files I provided in my post you can be up and running again in about 30 seconds.
http://www.cnczone.com/forums/g-code...k_can_you.html
