586,115 active members*
3,411 visitors online*
Results 1 to 13 of 13
    Sep 2012
    5
    USB stick Help
    I am using a 3 axis haas mill and i transfer program from memory stick(USB) to machine, it has stopped working for me now giving me a 197 misc software error. PLease Help.
    May 2004
    4519
    Did you try a different USB drive yet?
    Sep 2012
    5
    Ya, iv got 4 memory sticks and it doesnt work with any of them, it actually only reads one of the sticks which is also weird as it used to read all 4 of them
    May 2004
    4519
    Did you allow a Windows PC to "Scan and fix" any of the USB drives at any point in time? Windows has a bad habit of reformatting USB drives so they will not work on Haas.
    May 2010
    62
    Try a new one, make sure it's only 4 gig or less. No auto stuff on it. I've had some issues from time to time. Using old version (el cheapo at the local Fry's) an small capacity sticks cured the problem.
    When all else failed, I rebooted the machine and then things worked for a while. Then I started using the stocks I have now......
    Feb 2010
    1184
    They are also sensitive to static discharge. Always ground yourself to the machine before inserting the drive. Try cycling the power off/on and see if they start working again. If they do, it was because of the static charge.
    BTW, size of the memory stick does not matter. I use a 16GB with no problems.
    May 2010
    62
    They put the "upgraded harness" in my SMM and it was supposed to fix the grounding issue. It didn't fix the problem, so in my case it wasn't a grounding issue....
    May 2010
    62
    Quote Originally Posted by haastec View Post
    I was told by the local HFO tech support guy there was a recommended list of USB sticks, and none of them were over 4 gig.
    Feb 2010
    1184
    Just sayin!
    Feb 2010
    1184
    Quote Originally Posted by eaglemike View Post
    So what was on the list?
    May 2010
    62
    I'd have to find it - I remember one of the suggestions was the Kingston Data Traveler in the 2 and 4 gig.
    It's quite frustrating - I had them (local HFO) here at least 3 times when the machine was under warranty trying to fix it. It hasn't locked up lately... but it always happened at the worst time. Friday morning or afternoon, trying to get a job out.
    Feb 2010
    1184
    Always happens that way.(chair)
    I don't use mine daily, but no problems as long as I remember to ground myself first. Also, mine is an HP brand 16GB.
    May 2004
    4519
    I have a Kingston 4 gig, an Ativa 4 gig, and one of the Haas supplied 1 gig and they all work just fine. I have never tried my Lexar 64 gig because I have it dedicated for other purposes.
  1. stick font
    By helpmeout in forum CamBam
    Last Post: 01-29-2012, 06:12 AM
  2. Which lathe to stick with?
    By Scheer in forum Benchtop Machines
    Last Post: 02-24-2011, 08:48 AM
  3. Should I stick with CNC
    By MBG in forum Community Club House
    Last Post: 09-19-2009, 04:46 AM
  4. Sword Stick
    By ImanCarrot in forum WoodWorking Topics
    Last Post: 07-22-2008, 07:22 AM
  5. USB Stick as HDD
    By babinda01 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-17-2007, 03:32 PM
