- It's smart that you made the z depth shallow -- machine stiffness at the tool is proportional to the inverse square of the z height ( 1 / z_height^2 ).
- The tubular cross-member for the gantry is a good choice. For the 1300 length, 180x80 is probably on the small side for serious aluminum work. The 4'x8' commercial machines are in the ballpark of 200x200, I think. I'd delete the "ladder" pattern on the back and increase the main tube to at least 180x120 (to be both stiff and light, go for the biggest cross section with the thinnest wall). That will be much more effective, and less welding will keep it straighter. And it's simpler.
- The gantry tube will need some internal bulkheads to keep the cross-section from distorting into a parallelogram (from cutting loads in the long direction). The gantry uprights do that at the ends, but bulkheads are also needed spaced down the length. I've done some FEA modeling on a similar design and found just 2 internal bulkheads improved the stiffness at the tool by about 3x. To attach, some small rosette welds should minimize distortion, or use epoxy and bolts.
- It's good you made the main rails a little above the cutting table. I think that's optimum as it's in between both the CG of the gantry and the tool tip forces, to minimize both of their lever arms.
- The gantry uprights could probably use more stiffness in the lateral direction.
Keep up the good work!
