586,121 active members*
3,588 visitors online*
Results 1 to 9 of 9
    Mar 2004
    222
    Quadrature Encoder schematic?
    I got the servo(attached),
    it has shaft encoder, but I don't
    think it has quadrature output
    as it has only 3 wires, it's optical tho.
    I'm thinking maybe the photosensor
    can do quadrature but the circuit board
    is design only to read RPM, maybe I
    could modify the board to make it
    quadrature? any idea if it's possible?
    It's a JapanServo type DS48BE25,
    can't find info of it.
    TIA
    mhel
    "This is intentionally left blank."
    24221
    You need at least 4 wires for an incremental quadrature encoder, +, Com., A & B pulse.
    If it has three wires as well as + & com. then you are OK.
    You would be better off picking up a through-shaft encoder and replacing the 1 channel digital tach, if that is what it is.
    Al.
    Albert E.
    I looked at the picture of the encoder board and it is a single channel encoder.
    Mariss
    Mar 2004
    222
    I was afraid you guys would say that,
    I got 3 of these $5CAD each,
    I temporarily attached a heds encoder(I got from inkjet printer)
    so I could use it with UHUservo, but it doesn't fit very well.
    not enough space.
    it has 4 pins, but when I open it only 3 leads are connected to the board.
    "it is a single channel encoder."
    I'm thinking the board is single channel, but
    the photosensor? how do I know if dual?
    two LED. the top part has one LED like,
    and the bottom part has some tiny grills and has 3 wires too.
    thanks.
    mhel
    Mar 2004
    222
    I think I may have a chance to modify it.
    those tree wires coming out of the sensor
    red,green,black. Black leads to GND,
    bot red and green has signal on them,
    I'm just not sure if it is out of phase,
    my(unt)rusty oscope shows me kinda of sine wave tho.
    I wish I have another probe so I could see both at the same time.
    Is my findings make sense?
    mhel
    24221
    If they are in fact sine wave out, that is the way that all differential encoders start out due to the nature of photo detection and they are usually squared up before leaving the encoder, for example Hiedenhain encoders offer both choices.
    If in fact it is a sine wave, you could square them up with a schmitt trigger IC and even feed into a differential driver to produce 4 signal channels.
    In the absence of you double beam scope, after squaring you could test with a VOM on dc voltage range for each channel high and low, by carefull incrementing by turning the shaft.
    Al.
    Albert E.
    Jan 2006
    37
    I think red and black for the power supply and the yellow onw is one channel output. Why dont you try puting 5V into the red and black cable and use a led and a 470ohm resistorin between the yellow and the black cables. Then rotate the shaft and the led should blink. Its probable that it was used in a speed control where there is no need for dual channel encoder.
    Mar 2004
    222
    Al:
    it's definitely a sinewave, I'm going to try your suggestion.
    ez-cnc:
    the schematic I found(attached) is what led me to believed
    that I may have a chance with modifying the encoder.
    On the board that I have there's a separate supply for the infrared LED via,
    75ohm resistor apart from the three leads that's coming out of the photo
    detector, Black goes to GND, Red goes to 2k7(I think it's a pull up) and Green
    to trimmer pot. The IC is a JRC 2903D (if it's the same as LM2903D then it's a
    comparator, that's what I found at datasheet archive.com)
    thanks.
    Attached Files Attached Files
    mhel
    Mar 2004
    222
    it's quadrature alright!
    AL:
    I tried your suggestion and nothing happened.
    I got no signal on the output (74hc14) well it's alwasy HI,but
    still got signal from those 2 leads, then I noticed
    that the oscope is 1mV/cm. That means I'm getting
    a very weak signal coming from the sensor, so the input
    of the 7414 never go HI. I went looking for signal amplifier,
    but it's a little complicated than I thought.
    I was going to give up when I decided to separate
    the sensor from the LED, and voila!
    I found two sets of tiny grills one above the other.
    one looks a bit offset from the other. I used a magnifying glass,
    and it is offset, where the other has hole the other one is block.
    So I'm thinking this is how quadrature encoder works right?
    and the board it was attached to, was used only as a tachometer,
    by utilising both transition(HI, L0).
    so the quest is still on, if anybody could provide me with
    schematic so I could turn it into a quadrature encoder
    it would be greatly appreciated.
    My search on google gives me the idea that
    an opamp could be used (maybe like the one on the board)
    thanks
    EDIT:
    After a lot of searching I came up with an schematic,
    does it make sense? it's slow but I'm
    learning, I think.
    mhel
