586,102 active members*
2,658 visitors online*
IndustryArena Forum > CAM Software > Surfcam > overiding default settings
    May 2010
    I want to save the settings I use, such as rapid height, on the NC options page, but I do not know how. Each time I run a toolpath, the defaults return.
    Any help?
    Jul 2007
    148
    You could try saving it as a template. It should save the settings that way so when you program next time with the same tool and material, you can use the saved template and your custom settings should stick.
    Dec 2009
    80
    Hello,
    if you click "Tools-Options-NC Defaults" (see attached picture) and check the 3 boxes within the red rectangle, then I think your personal settings will appear next time you make a toolpath. It worked for me..
    Cheers, Thomas
  1. HOW TO CHANGE XFORM DEFAULT SETTINGS
    By dfearnow in forum Mastercam
    Last Post: 10-07-2012, 05:24 PM
  2. saving default tool path settings
    By Joesph Jackman in forum Mastercam
    Last Post: 03-21-2012, 05:39 AM
  3. Sinumerik 810M changing default settings
    By ignace in forum SIEMENS -> GENERAL
    Last Post: 10-07-2010, 05:18 PM
  4. Preferences / settings default
    By DIFF OVER in forum BobCad-Cam
    Last Post: 09-06-2010, 09:26 PM
  5. Mastercam 9.1 default settings
    By Fatty in forum Mastercam
    Last Post: 06-29-2006, 05:04 AM
