586,036 active members*
3,979 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > CAD CAM software for commercial use?
Results 1 to 2 of 2
    Oct 2012
    Cool CAD CAM software for commercial use?
    What is the best cad/cam software for commercial use?
    And what's the difference between cad and cam software?
    can't i use either one for cnc routing ?
    I am setting up a company here however i would like to know which software is good for both simulation and easy to use programming interface that would both do 3-axis and multi-axis (4 to 5 axis best if).
    What is the condition and fees for those license and what's that different from some opensource one?
    As in pros & cons?
    I am new to CNC so hoping to get a quick grip from your experienced machinist =)
    Many thanks,
    Sincerely,
    Daniel.
    Apr 2004
    5737
    Quote Originally Posted by papaonn View Post
    [That really depends on what you're trying to produce, what machines you're producing it on, and who is going to be using it.]
    [CAD stands for Computer Aided Design. It's used for creating a model or drawing on the computer. CAM stands for Computer Aided Machining. It analyzes the model or drawing you made in your CAD program and writes a program (usually) in G-code that is sent to the software that controls the machine so it can cut the part out of a piece of material.]
    [Usually you'd use both.]
    [There are many programs like that, but as you add advanced features like 5-axis machining, ease of use goes down.]
    As in pros & cons?
    [You'd have to get a lot more specific about what software packages you're interested in before discussing conditions and fees. They vary a lot. In general, though, open-source software doesn't come with any support, so you're on your own if you want to try it, with nobody to blame but yourself if you can't make it work. On the other hand, it doesn't cost money, just time.]
    Daniel.
    [I'd suggest doing a lot more reading about this subject before investing any money, but feel free to play with some open-source software to see if it does what you want.]
    Andrew Werby
    www.computersculpture.com
  1. CNC commercial brands?
    By marksaus in forum CNC Machining Centers
    Last Post: 04-02-2012, 06:30 PM
  2. IH in Commercial Service
    By bumperscoot in forum Charter Oak Automation Support Forum
    Last Post: 04-08-2007, 09:00 PM
  3. Replies: 0
    Last Post: 02-05-2006, 09:49 AM
  4. Commercial CNC Frustration
    By mcnotashark in forum Commercial CNC Wood Routers
    Last Post: 11-15-2005, 01:35 AM
  5. Info on commercial cnc...
    By Simpson in forum Commercial CNC Wood Routers
    Last Post: 08-09-2005, 04:34 PM
