586,061 active members*
4,308 visitors online*
Results 1 to 11 of 11
    Aug 2010
    Peck drilling with carbide
    Someone recently told me that carbide drills are not meant to be used with peck drilling cycles. True ?
    Jul 2005
    12177
    Sort of true. Probably more correct to say peck drilling is not needed with carbide drills running in the manner they can be run. That is high rpm and fast feed which tends to efficiently eject the chips making pecking unnecessary. The other reason for pecking which is to allow the drill to be cooled by coolant and let coolant into the hole doesn't apply because coolant should not be used with carbide drills.
    Of course if you are trying to cram a carbide drill as deep as its flutes will allow then problems are likely to occur and pecking can be tried. But this is not really the correct way to use a carbide drill. I don't have any literature about carbide drills available right now but I seem to recall the recommended maximum depth is 1-1/2 to 2-1/2 the diameter.
    May 2004
    4519
    Quote Originally Posted by rcs9250 View Post
    Totally true. Not "meant" to be. But in machining, you have to do whatever works to make good parts in a timely manner and get them out the door and make money while doing it. I have used carbide drill with peck drilling many times with great results, especially in 6061 aluminum where chip control was an issue.
    Aug 2010
    Thanks guys. We have pecked with them too, mostly on deeper holes where chip problems occurred.
    Jul 2009
    There are a lot of really good posts online about this subject and I suggest you research it in depth, few people really understand what is really involved during an actual drilling cycle, including speeds and feeds for specific materials/cutting tool materials.
    I highly suggest against pecking with coolant through carbide, period.
    I also suggest against pecking with carbide unless dire circumstances call for it. If you're not seeing results (regardless of material) and do not wish to do the research contact your tooling supplier and get the proper speeds and feeds or ditch the brand.
    Otherwise you're going to end up reducing/ending life of an expensive drill when you could have possibly been better off with a $2 HSS piece of Chinese junk.
    On a horizontal anything, rule of thumb (for me) is program a dwell only long enough to thin/break the chip.
    Mar 2006
    21
    Interesting....If we did not us carbide to peck drill we would not drill! I understand it can cause problems but you just have to work around them. You don't want the drill to rapid in on top of a chip or oops! You have to make sure you have good clearance for the tool. The G74 is a bad peck for this as it does not bring the drill completly out of the hole to remove the chips or allow coolant to flush the chips from the hole and the flutes. I use an incrimental cut and paste that will go any depth.
    (PECK CYCLE)
    G0Z.100
    G1Z-.1(-.100)
    G0W.125
    G04X1.0
    G0W-.1
    G1W-.125(-.200)
    G0W.125
    G04X1.0
    G0W-.1
    G1W-.125(-.300)
    G0W.125
    G04X1.0
    G0W-.1
    G1W-.125(-.400)
    ...........................and so on.....
    May 2005
    2502
    xyzer is right, it's all about exactly how the peck works, and most of the canned cycles are not helpful with carbide.
    Check out the Hole Wizard in G-Wizard Editor's Conversational CNC module for a simple way to create highly customized drilling cycles:
    G-Wizard Editor is Helping Folks Move Ahead « CNCCookbook CNC Blog CNCCookbook CNC Blog
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jan 2011
    pecking with carbide?
    carbide -peck drilling
    To get an answer, you should narrow your question by:
    -material
    -hole depth
    -lathe/mill
    For example, a 20XD hole can easily be drilled in eco-brass with no coolant and no pecking, except an occasional in-hole dwell, using HSS Guhring GT100 parabolic flute drills. Driiling stainless may call for pecking with same drill.
    I encourage the poster who said he had success with pecking carbide to give further details, since an ounce of experience is worth a ton of opinion.
    jb
    Dec 2011
    316
    Carbide - Peck - Coolant
    I recently completed a job which called for 600, 13mm holes, 1.5" deep in 6061. There were 5 groups of 4 holes each per part times 30 parts.
    I used a Titex carbide bit, G73, full coolant and 1700 RPM.
    G73 R 0.1 X 1.0 Y 0.0 Z -1.5 P.01 Q.075 F7.5 L4
    I realize that this runs contrary to conventional wisdom however it works well.
    I can only assume that a constant supply of coolant:
    1. Prevents shock cooling,
    2. Provides adequate lubrication
    3. Prevents chip welding.
    4. Provides chip evacuation
    There's theory and there's what works.
    John
    Jul 2005
    12177
    6061, barely 3 x diameter deep, carbide drill, 1700rpm, 7.5ipm.
    Isn't that a bit slow?
    I would go faster than that using a spiral point cobalt drill and expect it to easily last 600 holes.
    Dec 2011
    316
    Geof
    Blame it on a conservative old fart and a medium size hobby mill < 2 H.P.
    Bit is hardly used and will drill many more holes. Prefer the Titex cabide as it is rigid (no wandering) and no center drill is required.
    Not out to set any land speed records (applies to the drill as well as me).
    Post was only to demo that carbide drill bit can peck and use coolant.
    John
  1. G74 peck drilling
    By hackmeister in forum G-Code Programing
    Last Post: 07-26-2018, 09:29 PM
  2. peck drilling?
    By Tristar500 in forum BobCad-Cam
    Last Post: 01-20-2010, 08:25 PM
  3. Peck drilling on a 16/18i?
    By TheMoose in forum Fanuc
    Last Post: 09-09-2008, 09:34 PM
  4. Peck Drilling
    By RBrandes in forum Haas Mills
    Last Post: 06-19-2007, 01:03 AM
  5. Peck drilling
    By LarryMiran in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-23-2004, 11:12 PM
