587,012 active members*
3,694 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 11m EX05 Thermal trip alarm (power panel)
    Jun 2008
    6
    Kitamura Mycenter 4 - Fanuc 11m control
    During tool changing operation (M6) EX05 Thermal trip alarm (power panel) occurred, just before the arm takes the tool out of the spindle. Part of the operation is stop the coolant flow.
    We checked the thermal trip on the relays. Non of them tripped. However one relay "MS2" was not activated, 0V on coil. Relay "COL1", which activates relay MS2, same situation, 0V on coil.
    Checked the green fuses on power unit: ok
    Checked black fuses in cabinet: ok
    The electrical wiring diagram: following the circuit for MS2 we end at COL1 (coolant 1). From there I go further to CNT1 and CNTP in the ladder diagrams where I see a symbol RST address F000.2
    F000.2 can be found in the address list for NC-->PC.
    I have added several pictures of electrical wiring , ladder etc.
    What is wrong ?
    Thank you for your solutions,
    Rinus
    Attached Thumbnails Attached Thumbnails AddressList NC-PC (1024 x 616).jpg   Electric1 (1024 x 616).jpg   Electric2 (1024 x 616).jpg   Ladder legend (1024 x 616).jpg
    Jun 2008
    6
    Machine is working again. We found one more overload switch somewhat hidden in the cabinet which is not documented in the electrical wiring diagram. This one was tripped. Reset, and all OK.
    Regards,
  1. soft thermal alarm (OVC)
    By provcarl in forum Fanuc
    Last Post: 08-23-2022, 05:08 AM
  2. fanuc alarm 1000 mcb trip
    By dhiruj in forum Fanuc
    Last Post: 09-12-2012, 10:24 PM
  3. EX10 Thermal Trip - Fanuc 11M
    By Colorado Greg in forum Fanuc
    Last Post: 05-08-2012, 12:22 AM
  4. thermal alarm on f-20
    By settingbur in forum CNC Swiss Screw Machines
    Last Post: 12-23-2011, 10:24 PM
  5. Thermal Dynamics A-120 power requirement help
    By hailrazer in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-27-2010, 02:06 AM
